if it is the 'EWE' joint ...those can't simply be oiled can they?
Yes you can. you have to have a small needle and syringe then take some ATF and carefully pierce the rubber cup seal and place the ATF. it is a stop gap solution that may last several minute or several years. you can then try some corn head grease the same way but do the ATF first.
Thanks Collie. I jacked up the RTV and turned the wheels but no squeak. I drove it and no squeak for a long while. Then it started. So, maybe it has to warm up before squeaking.
