Thanks for the reply. I bet you're on the right track. I don't think the fluid is getting hot, although it does seem to get louder after use. The fluid looks good and doesn't smell burnt.I'm in the south so weather is still above 80 degrees. Does sound quieter at slower rpm's. How do you check bypass, relief valves? It is a cab tractor.
