Portable Generators Recalled by Champion Power Equipment Due to Fire Hazard; Sold Exclusively at Costco
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. It is illegal to resell or attempt to resell a recalled consumer product.
Name of Product: Portable generators
Units: About 8,600
Manufacturer: Champion Power Equipment, of Santa Fe Springs, Calif.
Hazard: Fuel can leak from the generator's carburetor, posing a fire hazard.
Incidents/Injuries: There have been 11 reports of fuel leaking from the generators, including eight reports of the generators catching fire and two of property damage.
Description: This recall involves two models of Champion Power Equipment portable generators. Both models have a black frame with black and yellow control panels, a bar handle and two wheels.
Model number 41332 has an open frame. The words "Champion Power Equipment" are on the control panel and "8250 starting watts" and "6500 running watts" are on the side of the fuel tank.
Model number 41532 has side panels that cover the long sides of the fuel tank. The words "Champion Power Equipment" are on the side panel above the control panel, and "9000 starting watts" and "7000 running watts" are on the control panel.
The model number and serial number are located on the side of the generator with the handle, on a tag on the crossbar above the yellow generator end cap.
Serial numbers at the CPSC site
http://www.cpsc.gov/cpscpub/prerel/prhtml13/13026.html
Units: About 8,600
