RTV 1100 relief valve relocation
wcmachine
Helllo, first post here.
I've found a huge amount of info on the function and adjustment of the HST system on this forum, it's a great resource.
I have a 2007 1100 with the HST relief knob on the dash. My understanding of the system is that the knob is attached to the high pressure relief valve and the low pressure relief valve is connected to the brake peddle. I need to pull the knob about 50% of the time during shifting while plowing. Because of the location of the knob, it's a pain to operate. I was thinking of connecting the knob cable to the brake peddle so it was always activated when the brake is applied. Does anyone know of a reason not to do this?
ovrszd
No reason that I can see. The ability to make fine tune adjustments would be essential. You don't want it to start dumping the HVT every time you touch the brake pedal. You only want it to perform that function when the brake pedal is "firmly" applied.
If you decide to do this please post a thread. Thanks!!!
