Net Tractor Talk
Go Back   Net Tractor Talk > Other Equipment Forums > Trucks, Trailers, Cars & Campers Forum
Trucks, Trailers, Cars & Campers Forum Trailers & Other Vehicles
Reply
  #1
Old 03-28-2009, 10:27 PM
jwstewar's Avatar
jwstewar jwstewar is offline
jwstewar is on a distinguished road
Default Chain Question
I've bought some chain to use to tie my little New Holland down to my trailer when I want to haul it. I bought Grade 43 3/8" inch chain. It has a WLL of 5400 lbs. These are 14 feet long with a hook on each end. So far I've bought 3 of them. Next time I'm at Menards I'll probably pick 2 more up. That way I have 4 to attach the tractor to the trailer and a 5th for any attachments that I haul. I'll then use 10k straps to tie the loader and any attached attachments to the trailer. Do you guys think these chains will be OK?
I know I've read say use Grade 70, but most of it that I've seen (unless I order it) is only 5/16 and has a WLL of 4600 lbs. Should I return my Grade 43 and jump up to the Grade 70 3/8?
BTW, I've got a little NH TC24 that with the loader, MMM, loaded tires, and an attachment on the back still weighs just under 4,000.
__________________
Jim
http://www.facebook.com/floweringgoatfarm
"What did you break now?"
  #2
Old 03-28-2009, 11:15 PM
urednecku's Avatar
urednecku urednecku is offline
urednecku is on a distinguished road
Default
I would think those would hold....BUT... if you are hauling very much you might want to check with your states Dept. of Transportation, to see what they require.
Of course, there will be somebody along in a little while with lots more experience and knowledge than me....
  #3
Old 03-30-2009, 07:44 AM
Posts: n/a
Default
Quote:
That's exactly what I'd recommend you do.
Here, it's grade 70, ESPECIALLY if it's a rolling load. 4 chains, off each 4 corners. Those 14' chains of yours could be cut down to 7' to accomplish this if you end up keeping them.
  #4
Old 03-30-2009, 10:29 AM
jwstewar's Avatar
Default
I just did a search and found this: Federal Department of Transportation
From what I'm reading, it looks like I'll be OK. Especially given that I'll be using 4 of them.
Actually, I lied. They are 20' in length, so maybe I do want to consider shortening them. I hadn't originally planned to. I think I'll load it up though and try it before I do anything.
__________________
Jim
  #5
Old 03-30-2009, 11:51 AM
jwstewar's Avatar
Default
After a little more snooping around, I think I'm going to order 5 of these: Grade 70 3/8" and a package of these 5 Rachet binders I can get the chain and binders for about the same price as 4 binders locally at TSC. I return the Grade 43 chain I've already bought. They may not take the one back as I've already opened it. Maybe be a liability issue. Guess I'll find out though.
__________________
Jim
  #6
Old 03-30-2009, 12:14 PM
Big Dog's Avatar
Big Dog Big Dog is offline
Big Dog is on a distinguished road
Default
Quote:
Looks like a great package, I'll have to look into doing the same for my soon to be new trailer. I'm looking for one right now for toting the Kioti (approx. 8000K# with BH on it)
__________________
My right to keep and bear arms should not be curtailed by the fears, phobias and paranoia of those who don't!
The original point and click interface was a Colt Peacemaker.......
  #7
Old 03-31-2009, 11:30 AM
PBinWA's Avatar
PBinWA PBinWA is offline
PBinWA is on a distinguished road
Default
I think it's recommended to use Grade 70 - as others have mentioned. I bought 4 Grade 43's just in case I ever have to tow my tractor. I don't really ever expect to have to do it but just in case I bought the four chains. I have some straps too so I would probably chain and strap the crap out of it and pray a little. If I was going to be towing frequently then I would buy some Grade 70's.
__________________
A government big enough to give you everything you want, is strong enough to take everything you have.
-Gerald Ford
  #8
Old 03-31-2009, 11:48 AM
GreenWannabe GreenWannabe is offline
GreenWannabe is on a distinguished road
Default
You might want to investigate the source of their chans and rachets. On other sites, I've heard of Chinese chain and binders being sold as grade 70, but made with an inferior steel and therefore not meeting advertised specs.
  #9
Old 03-31-2009, 04:10 PM
shvl73's Avatar
shvl73 shvl73 is offline
shvl73 is on a distinguished road
Default
Quote:
Interesting you mention that.
I had purchased Harbor Freight 5/16" x 20' grade 70 chains for $30/ea. I noticed Home Depot and TSC both had Chinese chains, so I figured, why not?
I then saw Lowes had US made chains for $35. I returned the HF ones and bought the Lowes ones.
  #10
Old 03-31-2009, 05:08 PM
Erik Erik is offline
Erik has a spectacular aura aboutErik has a spectacular aura aboutErik has a spectacular aura about
Default
thanks for the tip - I have 2 HF grade 70 chains but am looking for a couple more - will take a look at Lowe's. $35 for a 20' chain I can cut in half for my other 2 corners is a pretty tempting deal. (or maybe I'll cut my HF chains and use the US made for better applications)
__________________
Erik
addicted to tools and looking for excuses to feed my habit.
if we cannot make you have fun we will make fun of you
  #11
Old 04-01-2009, 06:43 AM
Posts: n/a
Default
Quote:
There is no better application then having a trailer load properly secured.
  #12
Old 04-01-2009, 07:56 AM
Default
Quote:
since I rarely trailer the tractor -- but I am looking at pulling out a lot of trees, I have to disagree on that one. My G70 HF chains are plenty strong for strapping the tractor down to the trailer -- I'm not comfortable with using them under heavy strain.
__________________
Erik
  #13
Old 04-01-2009, 09:59 AM
urednecku's Avatar
Default
How much strain you recon they will be under in a possible wreck?
IF the trailer was to flip, roll, etc. the load is to remain as one assembly, not having the load fly off and make 2 or more pieces of equipment flying in different directions.
  #14
Old 04-01-2009, 10:23 AM
jwstewar's Avatar
Default
I ordered the binders from the link that I posted above. For now, I think I'll stay with the 3/8" Grade 43 that I've already purchased. I'll let you know the quality of them when I receive them.
One thing I like about them, they each have their own little plastic "tool box" to store them in. Should help keep organized and from getting rusted just sitting in the bottom of a bucket or something. Should also make it easier to grab should I need just one. I know the case doesn't make the tool, but it is a nice little benefit.
__________________
Jim
  #15
Old 04-01-2009, 09:42 PM
shinnlinger's Avatar
shinnlinger shinnlinger is offline
shinnlinger will become famous soon enough
Default
2 thoughts,
If I was only hauling the tractor infrequently, I wouldn't cut the chain as it will be more useful longer for other things. You can also use 2 20 foot chains to secure your tractor by hooking at the 4 corners of your trailer and securing the tractor in 4 spots with 4 binders. THat way you still have 4 independent anchor points.
I will also say if you are pulling on a chain with your tractor you should rig something to slow down the chain if it breaks. I rachet strapped a hurricane fence gate to my ROPS. I could pop it off easy enough, but it has lived there for a few years now
__________________
Shinnlinger
'85 kubota 34 horse L2850
  #16
Old 04-01-2009, 10:46 PM
Default
Quote:
Originally Posted by shinnlinger View Post
2 thoughts,
Thought 1 is how I've been doing it, but it was sounding like I needed 4 separate chains to go with 4 binders - hence the cutting a chain idea.
Thought 2 - I saw a picture recently where someone used strapping of some sort to attach a piece of expanded steel to their ROPS, and I liked that idea a lot. Your chain link gate is a good idea as well.
__________________
Erik
  #17
Old 04-07-2009, 01:07 PM
jwstewar's Avatar
Default
The binders came yesterday. They don't say where they are made, but they have big letters samped right on them that say 9,200 WLL. They are fairly heavy. A little bit stiff, but most of them I've used through the years are. I will probably put a little bit of grease on the racheting mechanism. Of course, might be a little easier to operate when they are actually hooked to something as well. Last night is was cold so I just took one out of the box and was playing with it.
So far I'm pleased with their look. Will know more the first time I try to tie the tractor down.
__________________
Jim
  #18
Old 06-14-2009, 05:38 PM
tinkertoys tinkertoys is offline
tinkertoys is on a distinguished road
Default
Here the minute you go to a gooseneck trailer, you are subject to lots of stops by txdot to check chains boomers and commerical lic.
__________________
The older I get the more fun I have.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
