end caps on bed RTV-X11XX
CKing
The corners of our dump box have ~1" tube that the sides are welded to. One of cap plugs on mine is missing. I know it will filled with debris and then rust. So I bought 4 CAPLUGS for 1" tube and they won't hold made for heavier gauge side wall. Anybody know where get these?
hondajoe
End posts
Heres what I did.I cut a piece of foam to fit hole tight pushed it down about 3/4 inch topped it off with rtv scraped it off with razor blade while still soft to look good let it sit over night looks good and if you want to take it out later you can.JOE
CKing
I called my dealer and he has them at .59 so I'll buy 2 and hot glue them in. Cheaper than tube rtv and only mile away from my grocery run Monday.
