Rear Light Suggestions
I don't have a X1120 but here's what I put on my 900.
A simple tractor work light mounted under the bed. There was already a hole in the bed frame so I just used that for mounting.
BiffNH
I mounted two led lights just under the canopy. A switch on the dash turns them on. Unfortunately I have been unable to figure out a way to tie them in so they go on when in reverse. There is no reverse switch and I haven't taken the time to engineer one. I like the lamps up high because I think they are less likely to get broken. Good luck.
RandyB509
A reverse light switch would be awsume .. And a hitch camera for the rear.
pop in reverse and the lights and cam come on.. Hmmmm I am suprised one of you have not came up with such a switch yet.
well well,, I found this post.. and you guys have done it again ..Brilliant !
https://www.nettractortalk.com/forums/posts/101346/
This is terrific! I'd have given my left nut about a half dozen times this past winter as I would forget something when I went to feed livestock and would have to back down the gravel path in the dark. As soon as I finish a couple other projects I'm all over this.
