Rtv x1100c rear axle
FullDraw
Hi everyone, I’m new to the forum. Just picked up a 2014 rtv x1100c for $700 bucks. Needed some work but what a great machine. I need to replace the rear axle cv boots and I’m wondering what’s the process for removing the axle from the rear end. I know it’s a splined shaft but does the axle just pull out off the rear end? I am ready to try, have the wheels off, A arms and everything removed and out of the way. Thanks for the help, TJ
did you get this figured out??? i think the X models are just now beginning to hit the secondary and salvage market so you are the first to ask
FullDraw
Did it
Had to replace the outer CV boot Kabota only sells the inner so I bought a universal one from a local Polaris dealer. After pulling the CV shaft it was tricky how to figure out taking off the outer end. Once you remove all the grease there’s a small C clip in there once you get that out the big end slides off the shaft then you can put your new boot on.
