I recently acquired a 2003 ZD28 72" pro deck. The unit runs and cuts well but I've noticed on start up that the temperature gauge gradually increases but keeps going to red line and will sit there for 3-5 seconds before quickly dropping back down. This will repeat about 5 times before settling in at the middle of the gauge.
I flushed my radiator and pipes and refilled with a 50/50 distilled water/coolant mix from the dealer. Suspecting a faulty thermostat, I also changed replaced it along with the gasket. The issue unfortunately hasn't gone away. My next thought was to replace the thermal sensor by the water pump right below the thermostat. When I looked up the part it was described as a "thermo-sensor switch". I'm not sure what it switches because the radiator fan and water pump and connected directly to the engine output.
The actual thermal sensor is located at the back of the engine and when shorting to ground the temperature needle jumps to red and when cool is around 200 ohms (to chassis ground).
The problem is very repeatable and not sporadic so I don't think it's an electrical fault. For those familiar with control loops, it resembles a saw tooth pattern before ultimately regulating itself. Any ideas on what is going on here? My fluids are all at the correct levels.
