I saw a felling technique the other day called a notch-cut. I had never seen this before so I just went out and tried it. For those who don’t know, you start out with the usual wedge cut our of the face of the tree. Then you take the point of your chain (avoiding the kickback side) and basically drill through the tree. Once you are through the tree, place a wedge in the opening (on the back side) and hammer it in firmly. Then you cut the sides of the tree until the chain is almost in line with the edge of the wedge. Do both sides and then tap-tap-tap on the wedge. Down comes the tree.
