TEF sstarter lever
rustyorwhat
Hi All I have a sticky starter lever that won't travel enough to engage the starter Anybody got a gearbox diag showing selector rod travel and ball and spring position if any Als what is ki gas
stingray
the kigas pump is mounted on the tractor instrument panel and provided with separate fuel tank. The kigas atomiser is situated in the inlet manifold where the spray impingas on the heater coil, which is heated electrically when the preheater control switch on the instrument panel is pulled out. This provides a warm fuel vapour to assit starting the tractor in cold weather.
Sticky starter lever, maybe if the starter motor pinion will not mesh correctly or becomes jammed in mesh with the flywheel. it may be that the starter drive needs cleaning.
shona13
g'day stingray.
The starter motor is energised via a mechanical safety switch as you know,
to operate the starter you have to push the Gearstick into Start Yes.
The gearstick is connected to the manual start solenoid by a link rod and a 90 degree elbow,to access the start solenoid ,under the battery and bolted onto the clutch housing by four bolts, one bolt has the Eath/ground wire attached be sure to replace it when you are done playing with the switch.
disconnect the battery ,remove the four bolts lift the solenoid up and slide a srewdriver under it to hold it up then remove the small split pin and clevis that connects the operating rod to the switch, remove the switch and give it a good clean .
the switch can be stripped down and repaired ,the most common problem is the Copper contacts these can be bought from an auto electrical shop Best to find a shop that has een in business for at least sixty years otherwise you may get the runaround, when repaired refit the switch ,if you look closely the four retaining bolt holes are elongated this is to allow you to adjust the switch, it wll need alittle bit of Fiddling to get the switck in the correct position.
Happy Days.
Hutch.:tiphat:
