Newbie here with problem no 2, hydraulic pump is making a thumping noise when I start the tractor, all the hydraulics work even on my fel but you can hear and feel the thumping through the lines. I disconnected the pump from the engine to make sure it was the pump. The isolator was in pretty bad shape that I need to replace, but should I just put a rebuild kit in the pump, I really like to know what is causing the thumping noise, bad bearing or shaft or a piston?????. any help is greatly appreciated Thanks Steve
