heater fittings
malojeer
I am in the process of making my own heater for my RTV. I'm using a heater core from a saturn and a 12 volt fan from a vent in a travel trailer. What I need to know is what size fittings I need on the engine and the location that these fittings screw or tie into. Any help would be appreciated.
G
thats gonna be tough. If someone has the heater kit, the parts breakdown should be in there. </P>
ScenicHill
Believe you will find a plugged port on the thermostat housing for one hose. The second goes into the bottom radiator hose with a T fitting. Good luck. David/
