massey 1540 hydraulic leaking transmission vent tube after cold weather
case310350
Have a Massey 1540, 2007, powershuttle. After plowing in 2 degree weather i notice a hydraulic leak. Its coming from the transmission vent tube on top of the bell housing.
I noticed when the tractor is turned off i here some gurgling from the tube and the leak stops. This will happen when idling or moving. tractor operates fine, forward/reverse works fine.
I know most here won't have this tractor with this setup. Looking for a service manual any sources other than the dealer?
