Dan
I just got a Gilson YT11HE. I know you are at least familiar with them. I can fine no info on them. Perhaps I'm not searching with the right terms? Any help you can throw my way will be received with open arms.
It has an L head Briggs 12.5 hp I/C. I suspect this is not original. The steering rod to the left front wheel rubs on the left rear of the engine block. When the (38") deck is raised for transport the belt is at an extreme angle; the engine pulley may be incorrect for this engine, or the belt is too short. The mower blades will not disengage.
The PO bought it used, and had no documentation. If the pic I try to post makes it to the server, it is of the model # sticker -- the steering rod rubbing on the engine is visible at lower left. There is quite a bit of the oil pan boss worn away. I can take more pics when the mower is out of the sun (it's still on my trailer).
My main question I guess is do you think this tractor originally had a 12.5 Briggs? Or an 11 HP what?
