3000 ford diesel
imjwag
I'm trying to find the identification numbers for this tractor. Number on implement pad on right hand side of transmission is 35870C. No other numbers are with that one. On the engine block down by the oil pan....☆K395056☆
I would like to know what year model and any other Info needed.
I'm in the process of replacing the freeze plugs that are behind the flywheel and am at the point of removing the pressure plate and flywheel. Following the manual's directions to depress release arms and secure with wire.
Problem...that is the only details that is given. Is there a compression tool that is used or is a pry bar the way to go? Also, I don't see any location on the pressure plate to fix the wire to in order that it will hold the lever in the depressed position.
imjwag
Thank you....I went to that website after I posted the earlier thread and also came up with that conclusion. I appreciate your reply and any other help I can get...thanks again and have a great day!
