hi all</P>
i just installed a speedo in my 06 rtv, just wanted to say if anyone is interested in doing this it is a very easy install, it took about 45 min max, the instructions state to drain the hyd fluid.. but all i did was raise up the right side, lift the bed up and if you are quick you will only loose a few drops of fluid when you unbolt and pull the plug out before installing the new sensor, everything else is straight forward... the wiring harness is right there and easy to connect... and the wiring harness for the speedo head is also right there taped out of the way....</P>
it works like a champ!!! if anyone has any questions on the install please feel free to post on here and i will send you some pictures etc..</P>
thanks all and great forum</P>
