Are you talking about a 900? It sucks air from the front and that is why the 900's have the metal screen there,but the fine particles get past it. The transmission cooler under the passenger side ( on the 2011 and up) has no screen and it gets grass sucked up by the engine fan. also from the Dashboard side. I had a picture of that rat nest looking thing after a run through the pasture, but lost most of them on my computer. I have plan for it though. If you put water through the fan, don't get the electrical things wet such as the alternator or fuse box. I always blow all the water away as a precaution . bordercollieAlright so blowing it out is okay. I was thinking of putting some sort of filter either between the screen and radiator or in front of the screen. There's a post that gave me that idea...
http://www.nettractortalk.com/forums/showthread.php?t=15445&highlight=filter+radiator
How does the radiator take in air on these vehicles? Is it via a fan or passive? I always figured that little 'fan belt' was to power a power steering pump. But maybe there is a fan I'm unaware of?
