PTO attachment for skid loader
dog434
Has anyone made a PTO attachment to go on a skid loader so you can run pto equipment from your skid loader?
Thanks for any help
Bob
I'm no skidsteer guru but isn't the intent and general usage based on hydraulic implements?
What do you have in mind?
dog434
PTO
Yes but I have a snowblower I want to mount on the skid loader and it has a pto shaft to work. Have to find a hyd pump that will work a pto attachment.I would hook this up to the aux. hyd .
Bob
Red Beard
I don't have a skid loader, but do have a couple implements that use large hydraulic pumps on the pto which pump fluid directly to motors on the implements. As long as the pto is turning, the motors run. These systems run, and are isolated from the tractor hydraulics. One ditch bank mower does have a couple hyd cyls that control it which are run separately thru the remotes of the tractor, but these are still separate from the aux pump system. Hope this helps.
