imstephanw
Well I found the positive and negative wires in the back end of my BX1860 and took the tape off exposing them. I do know that they are on only if the ignition key is turned on, which is a good thing. Does anyone know if these wires are part of the circuit which runs all of the lights (20 amp fuse), or do these 2 wires run off a separate fuse. I want to run 2 lights forward and one flood at the back.
Thank you.
Steve
Thank you.
Steve
