cab heater
Stormriderblue
Hello Frank,
It is in the front of your tractor engine as where your water pump is. If you look closely in front as you see where your hose connect to or not. That is where your cooling locate (your water pump) of your tractor. I will get you a picture of where it is hook up to, that way you can get a very good idea to do the same as mine. It is very easy to work with.
