Working on a Massey Ferguson model 25. This thing has a little bitty hydraulic lift pump mounted to the top cover of the transmission. It is a gear pump and is only worn slightly but will only make 500 lbs pressure at full throttle. I rigged a tool that will check pressure directly off the pump and the pressure relief is holding to 1,900 lbs. I am having trouble locating anything for this tractor and really need a pump. If anyone can help I will sing at your next wedding. Anything you can tell me about this little French built tractor will be welcome.
Thanks Dan.
Thanks Dan.
