Net Tractor Talk
Go Back   Net Tractor Talk > Brand Specific Forums > Kubota RTV Owners Group Forum
Reply
  #1
Old 02-18-2020, 09:26 AM
RickW RickW is offline
Junior Member
RickW is on a distinguished road
Default Towing & Fuel Pump
Last night the RTV just up and died with no warning. Luckily I was only 50' from the shop and on pavement. I was able to push the RTV to the shop door but not over the threshold by myself. But it got me thinking about towing. If I had been on the other end of the property and this happened, would/could I damage the transmission in the RTV if I had to drag it back to the shop with the tractor for a distance?
As for why the RTV died and will not restart, it appears to be the fuel pump from the limited diagnostics I have been able to do so far. When I crank on it, it appears to be a fuel starvation issue/lack of fuel that is keep the RTV from firing up. Fuel tank is full. Same fuel as in tractor and no problems with tractor and have burned more of this batch of fuel thru the tractor. Fuel filter bowl is full and not cloudy. Filter is clean and only has 5~7 hours on it. Of course it was getting dark, the ground was wet, so I opted not to crawl under the RTV last night. Of course it started raining before dawn this morning. My assistant helped me push the RTV in the shop this morning. Will let it dry out/off and finish diagnostics this evening. Question: how hard is it to get to the fuel pump? Assuming it is on the bottom/front of the motor. So will have to drop the skid plates for access.
I have read the "sticky" fuel pump thread (after I was already leaning towards this being a fuel pump issue). I ordered a low pressure fuel pump off Amazon just to be safe. My Kubota dealer is an hour away each direction. So if further diagnostics still points toward fuel pump I will have it on the way. If not send it back.
So insight on towing (for future reference) and fuel pump access is greatly appreciated.
Thanks
--Rick
__________________
2014 RTV-X1100C
2006 B3030HSDC
The Following 2 Users Say Thank You to RickW For This Useful Post:
beagle hunter (02-18-2020), Doc  (02-18-2020)
  #2
Old 02-18-2020, 08:39 PM
Alaskanassasin Alaskanassasin is offline
Alaskanassasin is on a distinguished road
Default
There should be a bypass valve somewhere on the pump to release pressure and allow freewheeling. Luckily I havenít had to locate mine yet.
The Following 2 Users Say Thank You to Alaskanassasin For This Useful Post:
beagle hunter (02-19-2020), Doc  (02-18-2020)
  #3
Old 02-18-2020, 08:49 PM
aurthuritis aurthuritis is offline
aurthuritis is on a distinguished road
Default
make sure the solenoid on the fuel pump is working full travel.
__________________
2014 RTV X1100 CRLA 2014 MX 5100f 2008 RTV 1100cw
The Following 2 Users Say Thank You to aurthuritis For This Useful Post:
  #4
Old 02-18-2020, 08:58 PM
bordercollie's Avatar
bordercollie bordercollie is offline
bordercollie is on a distinguished road
Default
What did it do when you turned the key and attempted to start, after it went dead? what kind of Noises?
The Following 2 Users Say Thank You to bordercollie For This Useful Post:
  #5
Old 02-18-2020, 09:33 PM
Default
Before I went to a lot of expense, if it were me, I'd make sure nothing was blocking the fuel flow in/from the tank. We had a pebble somehow get in the trackhoe fuel tank and it did shut off the fuel just as well as a plug would have.
  #6
Old 02-19-2020, 07:19 AM
Westfield Westfield is offline
Westfield is on a distinguished road
Default
Quote:
Sorry for butting in on somebody else's post, I am trying to learn as much as I possible about these machines. How come you just can't put it in neutral when towing? Will the pressure in the hydraulic pump not release when the machine is turned off? I Googled how to relieve the pressure in a hydraulic pump, it looks a little more complicated than just pressing a relief switch. So I just want to understand this little more, if you are driving and the Machine would just shut off without you turning the key does this mean everything would be locked up and you wouldn't be able to put it in neutral?
The Following User Says Thank You to Westfield For This Useful Post:
  #7
Old 02-19-2020, 08:37 AM
Default
Quote:
when in neutral the HST is completely disconnected and the machine will roll freely. at least it will in my 07 1100 and the X1100C. if you need to relieve the HST pressure all you need to do is press on the relief poppet.
__________________
The Following User Says Thank You to aurthuritis For This Useful Post:
  #8
Old 02-19-2020, 08:54 AM
Default
Quote:
Thanks again, you are an awfully smart! Were you a service tech for these machines? I found out the answer after reading some more on the forms.
I should not have to bother you with my questions anymore, I found this forum which is very informative.
RTV HST Adjustments
Third Gen.. has a plunger(poppet) on the bottom right of the valve plate, hooked to brake linkage, which relieves residual pressures to ease shifting.
  #9
Old 02-19-2020, 01:57 PM
Default
Thanks Westield. no i am not a tech nor am i that smart but thanks anyways.
__________________
  #10
Old 02-24-2020, 10:32 AM
Junior Member
Default
Sorry for the delayed response. Work, life and everything else got this repair project pushed off until finally Saturday afternoon was able to dig/diagnose it further. It was the fuel pump as I suspected. First I pulled off the hose on the output side of the pump. Pumped the hand pump several times and only a trickle came out. I then placed a wad of shop towels at the output side of the pump and cranked the key. Again barley pumped any fuel into the shop towels.
When I disconnected the input fuel line to the pump and pulled it back down thru the frame fuel ran freely. So no reason to suspect a blockage in the fuel line at that point. So I then decided to hook up the electric fuel pump I purchased on Amazon real quickly and see if that solved the problem. Couple of jumper wires over to the battery, the pump came alive. Turned the ignition key to start and the RTV roared back to life.
Took longer to find a location to mount the electric pump and run the wiring correctly than to actually isolate the problem to confirm it was the pump. Now if I was trying to replace the factory pump then it would have been a different story. Just getting my hand in there to move the hand pump was some work.
__________________
2014 RTV-X1100C
2006 B3030HSDC
The Following 5 Users Say Thank You to RickW For This Useful Post:
beagle hunter (02-24-2020), bordercollie (02-28-2020), Cajunrotor (02-25-2020), Doc  (02-29-2020), shinnery (02-24-2020)
  #11
Old 02-28-2020, 09:04 PM
Default
Haha not sure why I over complicated that! Thanks for clarifying
beagle hunter (02-29-2020), Doc  (02-29-2020)
  #12
Old 02-28-2020, 09:21 PM
Default
Thanks for letting us know . Happy that you have it fixed. Ahhhh.. what a feeling.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2019, www.DotHQ.com
