I looking at a 2040 John Deere to buy. After running fro about 15 min it loses most of its hydraulics. The load or 3 point hitch will barely lift. It has a tandem gear pump on it. The guy selling it let me flowmeter the pump. It started out at 6.5 gpm at full throttle at 0 psi and about 6 gpm at 2200 psi. but it quickly dropped to 3 gpm at 0 psi and about 2.75 at 2200psi. From this I do not think the pump is bad. The seller said he has chaged the trans filter and clean the suction screen. I removed the low pressure relief and the trans filter relief and did not see anything wrong with them. Is there any way to flowmeter the transmission pump or any other test I can do to find the problem.
