Maintenance/service question
tlk
I have an 1100 with 280 hours on it. Had if fully serviced last year and put a little over 100 hours on it since then. Most of the hours was in south texas - heat, mud, and mostly dust. Also the majority of the time I am using this buggy I am in remote areas and need it to perform. If it breaks down then it is a major issue to get it to a dealer and also leaves me without a hunting vehicle
I am taking it in for service and want to know what all I should have done.
I plan to have all belts and hoses looked at along with the boots. The book calls for these things:
Brakes - change fluid and seals
Replace flush coolant and replace
grease
replace remote hydrolic hose?
replace hydrolic oil?
clean all air filters
It does not call for oil change and new oil filter yet but should I go ahead with that?
What should and should not be done?
Thanks for the input
With a hundred hours since a full service, I'd change the engine oil and filter, check the air cleaner, check the tranny fluid level and top up if required, grease the few fittings, make sure the spark arrestor is clean, and keep going. I've never messed with the brake fluid or brake seals and mine has 2,050 hours on it.
Fitch
