markmccarthy
have a new RTV 400 and it sits about an inch low on left side. Kubota advised that as the engine etc are on this side that is normal!! As the engine, transmission are attached directly to the chassis and wheels and as they are not attached to the suspension this is not the problem. Have seen other comments on this and looked at other new ones which are the same-anyone have any ideas as Kubotas' only suggestion was to buy a suspension block from them to correct!! We think that it is a design fault and as such should be fixed by Kubota. Does anyone else have this problem, it is easily seen if parked on a flat surface and viewed from rear.
