its 60 degrees here in houston,and i did fill filter and fuel flowed well when i lowered the gas line and put more fuel in ,I have 8 volts going to glow plugs and i bled the pump and checked lines to injectors and fuel comes out when i turn it over,but very little no smoke when i turn it over and no popping any more,for a while it seemed like one cylinder was firing,the only fuses i checked were the glow plug and the 2 big main fuses,i am lost tomorrow i was going to take valve cover off and check valves and cam
