Net Tractor Talk
Go Back   Net Tractor Talk > Other Equipment Forums > Yesterdays Tractors Forum
Yesterdays Tractors Forum Old Iron. Pictures encouraged.
Reply
  #1
Old 10-11-2018, 03:01 PM
k9yli k9yli is offline
Junior Member
k9yli is on a distinguished road
Default farmall m IDing parts/model
I am in the process of ltrying to fix a plug fouling problem mostly cyl 2,3,4...
It turns out it is non standard.. Pistons are 4 inch M&W. but flat topped..!!
It should e a gas only tractor (1950) I need to get new rings and gaskets.
That is not a big concern right now.. but I would like to know engine model ( I think its C248) and why most of the stuff I have found in the last couple of hours indicates M&W have either cratered/recessed or ridged pistons.
pictures if it works
edit: crank is 5.25 stroke..not the 5.75 m+w change.
The Following 2 Users Say Thank You to k9yli For This Useful Post:
Doc  (10-11-2018), thcri (10-16-2018)
  #2
Old 10-16-2018, 04:56 PM
Junior Member
Default
so far,, c248 seems correct for engine. also rings for 4 inch M&W pistons is 2C7997 set... It seems that is correct for all versions of 4 inch M&W
pistons. Pistons are marked 11F3 inside skirt. Flat topped.
top two rings are 3/32 next is 1/8. oil ring is 1/4
Head in machine shop to swap valve guides. and remove one broken exhaust stud.
I will keep in touch if any further concerns arise.
Don..... north west wisconsin..
Doc  (10-16-2018), thcri (10-16-2018)
  #3
Old 10-16-2018, 08:26 PM
Doc's Avatar
Doc Doc is offline
Chief Bottle Washer / Admin
Default
Good luck and thanks for updating this thread.
__________________
Scott me up Beamy!
Other Fun Forums:
Forums Forums .com +++ Net Cooking Talk Forums +++
The Following User Says Thank You to Doc For This Useful Post:
thcri (10-16-2018)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright 2002 - 2020, www.DotHQ.com
