I have a 2008 Kioti DK 40 SE Stick Shift Transmission and it becomes very hard to shift from Foreward to Reverse after it's been worked Hard. Two seperate Kioti dealers have taken the transmission apart under warranty and have not found any major problems. Has any one had this problen or any suggestion? They have changed the shifting fork and rod and all syncros and still have the same problem. They said the clutch is fine and has very little wear and it is adjusted correctly. This problem has been going on since new. I have 420 hours on the tractror.
