[quote user="ba7man"]Be careful installing the lift kit. It will prove challenging and you must follow Brian's modified instructions. Good luck[/quote]
Glenn,
Glad my "modified instructions" for the lift kit worked for you. I just bumped the thread as it was several pages down but I didn't want it to get buried.
BTW - (For Anonymous) - If you're on relatively level terrain, and not under heavy loads (i.e. plow in front), you can get a 26-27" tire installed without the lift kit. The only rubbing I encountered was when going down a steep hill, into a sharp turn with over 1000# of firewood in the back. Under those conditions, I would get a slight rub on the front inner tire. In my terrain (very hilly), I would have preferred NOT to put the lift kit on as it raises the center-of-gravity.
