Newbie here just picked up a jd 2840 with a tas 500 fel, runs good but I'm trying to fix a oil leak at the steering linkage oil seal, I'm down to trying to get the steering shaft off the steering shaft arm. I have the steering shaft cover off and everything out of the way but I can't get the shaft out to change the oil seal, I haven't tried to force it are anything, soaking it in oil now to try and make it easier to get out, that's the question should I try forcing out are hammering it out. all help is appreciated THANKS
