Case 2094 Cannot Shift into gear
pistolnoon
Anyone with mech-hydraulic experience on the Case 2094, my brother backed up to the vibra shank to hook up and could not shift back into gear I thought it was just the interlocks not allowing the tractor to start but you can start the tractor the back hyraulic ram works so the pump is ok and the shift levers linkage works but the tranny makes no sound and seems dead, I power washed and checked the solenoids but cannot find anything apparent and not sure where to start, the fuses are ok, the unloader linkages work, when I go to shift into gear the gears grind lightly and I don't want to force it, their is no filter bypass light on for transmission or oil warning as I thought maybe the pickup screen plugged?
Anyone have any knowledge on this problem?
