Rod the stick welder
Has anyone seen the cast bracket alum.break off the pump due to the exhaust pipe broken? Just got one in the shop broke the bracket and took a chunk of alum. leaving hole in the top of the case..
I haven't taken pictures. If I find the time I will. The fix was done under warranty. As soon as the exhaust pipe separated from the manifold I called the dealer and reported it. They were a bit slow at getting back to me in the meantime, in spite of not using it much, the bracket on top of the transmission snapped. I agreed to have them weld the bracket and the exhaust pipe/manifold instead of fighting to have the transmission housing changed out. The person who welded it did a fine job and I suspect it is good or better than original. At least I have it recorded that the repair was done under warranty. There is a thread here that talks of the same separation of the exhaust pipe and manifold.Bummer. What's the fix it plan?? Got any pictures??
Mark, You hit it perfect on the head the exhaust should not be mounted on a critical part of the driveline. We took some time and drew up a bracket that fits on other parts of the driveline and put it on our cnc plasma cutter to make multipules.Ihave not found what a pump costs but I sure its not cheap. This bracket should be removed and relocated before it breaks the alumium casting. In therory the motor is tied to the pump along with the exhaust but watch it shake at idle.
