Net Tractor Talk
Go Back   Net Tractor Talk > Brand Specific Forums > Kubota Tractor Forum
Reply
  #1
Old 12-22-2010, 08:07 AM
1kubota 1kubota is offline
1kubota is on a distinguished road
Default 3 point hitch
Hi Folks, Since I own a tractor I shouldn't have to ask this question.. But here I am.. What is the difference of a catagory 0 and catagory 1 hitch? They both look the same to me. I think my BX-2230 has a catagory 1 ? Has anyone used a box blade a a snow blade? The back of the blade looks plenty tough enough.
Thanks
Larry
  #2
Old 12-22-2010, 08:48 AM
Erik Erik is offline
Erik has a spectacular aura aboutErik has a spectacular aura aboutErik has a spectacular aura about
Default
the easiest way I know of to tell is pin size - IIRC, cat 0 has 3/4" pins and cat 1 has 7/8" pins.
I use my loader and BB to scrape snow -- mostly pulling forward so I don't bend one of my lift arms.
__________________
Erik
addicted to tools and looking for excuses to feed my habit.
if we cannot make you have fun we will make fun of you
  #3
Old 12-22-2010, 04:45 PM
Default
Erik, Thanks for getting back. I don't have a back blade. Thought I would pick up a box blade and kill 2 birds with 1 stone.
Larry
  #4
Old 12-22-2010, 05:44 PM
bczoom bczoom is offline
Default
A box blade is kind of hard to do snow. Between the sides and the fact you can't angle it, everything collects under the tractor. What do you do with it then? Also, because of its weight, plan on it getting down to your surface pretty quickly. On stone, it'll be pulling it up and on concrete, it'll scuff it pretty hard.
  #5
Old 12-22-2010, 06:35 PM
Default
You're probably right about the weight. I was planning on pushing backward. I had a brain fart.
Larry
  #6
Old 12-26-2010, 06:14 AM
Harvey Harvey is offline
Harvey is on a distinguished road
Default
1Kubota, look around for a back blade, a used one can be had for $2 - 300. You'll find they work well.
Harvey
  #7
Old 12-26-2010, 10:08 PM
horsefarmer horsefarmer is offline
Junior Member
horsefarmer is on a distinguished road
Default
No brain fart - use box blade both ways. Pushing snow or pulling. Weight helps and does no damage to asphalt or concrete drives when properly adjusted. I have Snow Boss plow on 1 ton 4 wheel drive diesel dually and sometimes use tractor and box blade. Both move snow well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
