Net Tractor Talk
Go Back   Net Tractor Talk > Brand Specific Forums > Kubota Tractor Forum
Reply
  #1
Old 07-23-2011, 12:34 PM
1kubota 1kubota is offline
1kubota is on a distinguished road
Default BX 2230 stutter
Hi all, I've got another question/problem. My Bx2230 will missfire/stutter every once in awhile. I use Power Service year round supplement to prevent this type problem?? I usually don't run the tractor much more than half throttle but don't use it for heavy work either. Could this be causing the problem. Tractor only has 530 hrs. Would it be possible the fuel is drawing condesation? I keep it inside. Any thoughts will be greatly appreciated.
Thanks
Larry
  #2
Old 07-23-2011, 07:16 PM
kevinj kevinj is offline
Junior Member
kevinj
Default
Change the fuel filters
  #3
Old 07-24-2011, 07:57 AM
Default
Very good idea. Must of had my head in the sand. Why didn't I think of that??? Duh me..
  #4
Old 08-14-2011, 06:33 PM
Default
Stutter update, Really had my head in the sand on this one.. The seat saftey switch was the problem. When I would lean to the right or bounce the switch would loose contact. Bent the switch bracket up just a little, fixed the stutter problem.
Thanks
Larry
P.S. Should the hydraulic fluid be checked, cold before starting? Hot after shutdown? Hot while running? Manual doesn't specify.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
