1/3rd Scale Rumley and 1911 Silage Cutter
trrjohn
Here is my 1/3rd scale, home built Rumley powering my (to be restored) 1911 Ohio Silage Cutter.
Also trying the full size Baker Fan with the 1.5 HP.
trrjohn
The 1/3rd scale Rumley has a model A front end narrowed with steel wheels from an old silo filler carraige. The rear end is cut down model A with the ring gear replaced with a 50 chain sprocket. The engine is a restored T&G, 1.5 HP McCormick Deering. A 'B' size v belt serves as the clutch and drives a '50 Chev 3 speed transmission, which then powers the differential with roller chain. The rear wheels are from the steering axle of an old horse drawn manure spreader. The frame and "muffler" are fabricated out of mild steel. It runs about 3-4 mph in high gear. It powers some of my restored toys at various "old engine & tractor shows".
John
Very Kewl. I saw a similar setup at one of the Meigs county fairs in.
trrjohn
Thanks for the kind comments. It would be nice if spring arrives so I can "Play with my toys" again.
J
