1954 860 ford tractor
I have a 860 that the rear lift wont work it has a vane pump on it the hydraulic fluid looks milk like and is over full can this cause my lift not to work
TY
David
Yes. The milky look is water in Hydraulic fluid. You should change Hyd fluid and Hyd filter ASAP. That should fix problem. Next you should find where water came from and fix leak (like gear shifter boot could be cracked and letting water in).
