Possibl bad or faulty ground? Check/clean neg terminal/post on batt and clean chasis ground strap? I've had this problem before - hi current draw units would not work but low current draw would.Was using winch and then entire electrical system quit working. No crank no horn no lights. Battery good. Cables good. Fuses good. Power to starter 12.7volts. Power out of starter via blade clip 0 volts. Can a bad starter cause entire electrical system to quit working?
Agree with BCzoom - - you could "hot wire" the battery directly to the starter solenoid to check if the starter is bad. Did you check fuses visually or with a VOM (volt ohm meter)?When this happens to me on my machines, each time it was corrosion inside the battery cable (normally the negative cable). The corrosion is inside the insulation so you can't see it. You may get voltage reading since it may get a few amps through the cable but it can't get enough amps through the wire to the starter. To test, take a good jumper cable in parallel with your battery cable and try to start. Repeat if needed on the positive cable.
It's been a bit over a month. Got it fixed? If so, what was the issue and resolution?Thanks guys. Will try that. I tested all fuses with a VOM
