Greeting All!
Had a squeaking/scraping metal like noise develop on the 900. Sounded like it was coming from the front drivers side and only when in 4 wheel drive. Got under and took a look - had a ripped outter CV boot (drivers side) and lots of crud on the axle. Some shearing on the metal inside joint was seen. Replaced both CV axle shafts (American CV product). The noise is still there despite the fix and still only when in 4 wheel drive. Sounds worse when I make a very tight left turn. I'm sure the CV axle needed replacing - it was original (~2500 hrs on 900) and looked pretty bad, but still confused on the source of the noise. Any others seen or heard something similiar? Welcome all thoughts and suggestions.
Thanks!!
Thanks!!
