2014 rtv x 1100c stuck brake
mikeyttt
I have a 2014 rtv x 1100 C, no matter what I have tried, I cannot get the right side rear brake unstuck. I have soaked with PB and Kroil, I have tried heat and freeze off.... any other recommendations? I got the drivers side free fairly easily but the passenger side just won't let loose. I really dont want to tear into it if I dont have to, but if I do have to, what is the easiest way to do so?
Thanks
The brake is internal and runs in oil. Is your gear case oil at full on the dipstick? Tap the external lever back and forth with penetrate and disconnected from the link. If it's not an external rust problem then the disks in the brake are probably warped from heat and need replaced. It's not a particularly hard job to do. Get a shop manual.
Yes, fluid is full and that lever will not move at all. I do have a shop manual downloaded, I will look itnover for the brakes. I assume its a problem with the steel sticking to the aluminum since the left side was that way too. But I didnt think about the brakes being warped possibly. Thanks for your input
Have you ever done the brakes? Is it possible to do this with the trans still in the machine?
Yes no need to remove the transmission. Take off the wheel and remove the half axle the the ring of bolts around where the axle goes through. Pull out the brake assembly and rebuild. Reverse the disassemble to put it back together.
When you put it back together use your axle shaft as a pilot to align the splines in the brake disks before you put it back in the machine.
Do you think it would be possible to support the trans, drop the trans crossmember, and the gain access needed to pull the side on the case?
I think all you need to do is disassemble the suspension pull the axle and take the brake assembly directly out of the side. The ring gear and pinion will be visible but unaffected
As long as I can pull both those side covers, I guess ill be in good shape
