2014 rtv x900 won’t start
Medic167
The fuel line from the tank to the filter came off, I put a clamp on it and filled the tank. Now it cranks but won’t start. I loosened the intake lines and tried to crank it, but I’m not getting any fuel or bubbles. Any ideas?
Did you let the diesel fuel run out of the filter when you refilled, or is the filter clear looking ? Just wondering if there was air in the filter area. When I changed my fuel filter, I always used clamps so the fuel in the upper line would be held there as well as from the tank. Also wonder if the tank is clear of debris at the connection? When did the fuel line come loose? It it was a good while ago, it may need priming as you were doing . Others will chime in, Welcome to the forum , :)
The fuel line came off while my son was joy riding on it. There’s fuel in the cup where the fuel filter is. I don’t know if there’s fuel past that point. I’ve loosened the bolt where the fuel lines enter the valves, not getting anything coming out of them.
