3140 pto
1085
my 3140 when blowing snow or cutting hay makes a rattling noise,whats up with that?the 3 point hitch also slowly go s down when the tractor is turned off is that normal.
thanks 1085
Welcome to the forum!
The 3-point going down is pretty normal. My Deere does the same.
On the rattling noise, is it coming from inside the rear-end of the tractor or is it in the PTO shaft itself? With nothing connected to the PTO on the tractor, does it make that noise when you engage? Rattling in my experience is normally in the PTO shaft and it's related to the U-joints not being lubricated or failing.
it seems to be around the clutch and when theres no load or slowing down.used on different eqiment same noise.the tractor has 9000 hr on it same clutch
thanks again 1085
You just went inside the tractor and in an area I have little to no expertise. Anything I said at this point would be speculation at best. Sorry. Got any friends or neighbors that could listen to it and give their thoughts?
