4 x 4 stuck
my B7100 is stuck in 4 wheel drive everything else is fine . any easy ideas?
Jeep owner manuals used to say to back up in a zig-zag pattern while pulling on the lever. Or you can jack up one side in front. Either will unwind tension in the driveline.
My B7100 hst was stuck in 4WD too. I'd just bought it used and it had been sitting awhile. I jacked it up so one side wheels, both front & back, were off the ground. Turned wheels by hand & jiggled 4WD lever; it came right out. I WD40'd the lever, cycled it a few times & haven't had trouble since. I hope it's that simple for you too. Best of luck!
