4540 4wd from axle disassembly
Aequitas_9
We have a leak coming from between the axle and hub. I assume it's the axle o-ring or the seal itself or both. I have separated the hub and removed the 1 1/8 axle nut. I thought I could just press the axle out but it's not budging. My local shop will not return my calls. Does anyone have experience with the removal of the axle from the front hub? It is the circled diagram below.
I just ran into the same issue... Haven't taken mine apart yet... Following for possible help or maybe I can get mine apart and help you.
426 hrs. She's a workhorse! Stuff is going to break over time. This is the only problem I've had with her besides the front driveshaft bearing... and that was just a fluke deal. She'll do more than what the manufacturer says if you know how to use her. Keep up with the maintenance!
And an update... when you replace the oil seal, you have to replace the 2 O-rings as well. Do not re-use them.
I have the same issue with my 4540 tractor. I attempted to take it off once and got tot he same issue where the hub/axle needs to come out to replace the main seal and I couldn't get it to budge. Let me know your thoughts, and thanks
I took my 4540 tractor apart and found I was unable to take the bevel gear apart so I took the hub assembly to the Mahindra dealer I bought it from and they advised that there was a bulletin ( recall) on that part. So the company is replacing the assembly under warranty since it is still under warranty. Hope this help.s
