After reading several threads here about possible fires on RTVs - I elected to install a quick release main battery disconnect on my RTV900 in the event of the unthinkable. If a wiring short occurs you can quick and easily flip this arm on this unit to disconnect the battery neg terminal immediately and hopefully contain the damage. Installs in 5 min - just take off the cable on the negative post and put this in place. The negative cable now is installed in the adjacent post and makes contact with the copper lever. Got this at tractor supply for about $20.
Still would recommend carrying a fire extinguisher just in case!!
