BX Hydraulic Control Lever ?
lb59
Lever does not return to the neutral position like its supposed to after lifting or lowering an implement.
What's the fix for that problem?
WRG
I have the same problem, checked oil level, and added to full mark(about a pint)
stuck in down position. The Maintenance Manul sugested turning steering wheel right and left several times to release air traped in system, or replaceing the Strainer. Thow it seems that it is a mechanical issue back pressure could be the problem. I have not tried either of these yet.
