Deere 2032R Series 1 wont move
J Rodgers
Hi all,
I have a 2032R Series 1. I went to use it today and it cranked and ran fine. Picked up a few small limbs with the grapple and then no forward or reverse. No grinding or noises at all. Nothing out of the ordinary just poof it stopped moving! I have rear wheel weights, but no water. Oil level good, replaced the trans filter for the heck of it, power steering is good and PTO works fine. All implements work just fine. Front wheel drive does not engage now either and using diff lock makes no difference.
Also, the Low Neutral High lever is moving the shaft that goes into the transmission, and the F and R pedals sound like they are stroking the pump.
Any ideas or expertise from the forum is much appreciated.
