Diesel Fuel Filtering
Ohio_Pawpaw_Grower
I was new to diesel when I got the BX2230 and then the X1120D.
I had to buy a couple of new fuel containers, yellow so that my lovely Mrs and the kids did not accidentally put the wrong fuel in the right tank.
When I get a new fuel can, I rinse it with water thoroughly and let it dry upside down in the sun. Once it is completely dry, I install the ezflow high volume spout and its vent. Once that is done, to insure nothing fell into the tank, I hit it with a little compressed air and inspect it.
OK, so both of these cans were then filled with diesel and I filled up my equipment. Now empty, I brought them home from the farm to re-fill them and noticed a considerable about of floating crud in the bottom of both cans. Remember, they went from the fuel station pump directly to the farm when they were used and never exposed to anything else.
My question for you folks who have more experience with diesel, does it usually have a lot of crud in it from the filling station? I noticed two large filters inline on the fill hose. Could crud be getting through those filters?
Appreciate anything insight on this.
California
I tried filtering diesel through Mr Coffee paper filters and found it soon plugs up so nothing will pass. My next try was a cone shaped fine mesh gold plated coffee filter in its funnel-shaped coffee maker, the type where your pour hot water into the funnel. That worked ok.
I've also used HF's paper paint filters, the type you set in the top of a spray gun quart paint reservoir, that worked ok.
These measures are to prevent debris from plugging the fuel lines. The engine's filter should prevent abrasion wear in the injectors.
The owner's manual for my 40 year old Yanmar expects it should tolerate a huge amount of junk in the fuel, it says something like "if debris or water in the fuel exceeds (a tablespoon) per tank fill (5 .8 gallons) then expect to replace the fuel filter more frequently". That quantity of impurities must anticipate some place where fuel is delivered and stored in 55 gallon drums way up in the back country, in some remote country.
I remember that some members used to use a funnel called Mr Funnel or Filter. Something like that. If I remember correctly Two Guns loved his and thought it was great.
On our diesel tank, we have a Donaldson fuel filter that captures water as well. If just debris though one of the screened filters would work - we have condensation though so need the water capture filter.
California
Mr Funnel. As I recall these were first promoted for bush pilots to refuel at some remote site where fuel may have been stored long enough to have condensation, and maybe rust flakes and bacterial crud. Similar for boating.
Claimed to stop all water.
I too am a fan of Mr Funnel. My bulk diesel tank sits with stagnant fuel for pretty long periods. To avoid the need for filtering, I just don't use what's on the top or bottom of the tank. I use a "shaker hose" and pull fuel from the middle. When it gets low, I'll start filtering again figuring the last 10% or so has all the crap.
Ohio_Pawpaw_Grower
It sounds like crud in the fuel is something you have to live with when you use diesel. I thought maybe it was just my station. I will get this can cleaned out since it is empty and pick up one of those Mr. Funnels. Looks like you could run 5 gallons through one purdy quick. Thanks for the tips.
crud in fuel is not a normal thing in diesel fuel. it is common tor the spouts on cans to get cobwebs and stuff in them even hoses looped with the nozzle up and not capped will get rain and leaves and stuff in them. the smaller the container the more likely you are to get crud.
FTG-05
Another fan of Mr. Funnel. I use it whenever I need to refuel from my MFCs. Having a farm fuel tank is sooooo much easier though!
geohorn
Here's the solution I've made: I had two friends who gave me some equip't they had no use for... an old 160 gal propane tank, and a 30' delivery-hose/nozzle which was a new replacement intended for a marina system (his BIL sold the marina and had no further use for the new hose/nozzle.) The 30' hose is much longer than needed but has proven useful after-all because I don't have to maneuver/bring the equipment up close to refuel them.
Propane is a "sweet" fuel so I wasn't too worried about the inside of the empty tank but after removing the valves I did look inside with a bright light and found it relatively clean. I figured with a good filter and if I pick the fuel up from a few inches off the bottom there'd be no issue...and so far, that has proven to be true. Absolutely no water or debris has been found in the water/particulate filter so far.
The system is powered by shop-air delivered from my hangar (which you can see in the background) via a regulator set at 10 psi. (Any more would cause the nozzle to "jump" in the hands similar to an unconstrained fire-hose.) Shop air is dry because the shop compressor has a water-separator on it. The air enters the tank thru an air quick-connector, thru the regulator w/gauge, then thru a ball-valve to the tank...pressurizing the tank/fuel.... which is pushed up a dip-tube which has it's bottom end 2" above the tank bottom. The fuel passes up the dip tube, thru another ball-valve, then thru the water/particulate filter, then thru a set of hydraulic quick-disconnects into the hose to the nozzle.
The reason for the quick disconnects on the hose is for when I use the tractor front-end-loader to place the tank on my stock-trailer to haul the tank to the fuel distributor (saving another ten-cents/gal) and the reason for the three ball-valves is 1) to close the tank air inlet, 2) close the tank fuel outlet, and 3) vent tank pressure to atmosphere if necessary (for example, before opening the cap to re-fill the tank.) The ball-valves also are arranged so that in order to remove the tank cap, the valves MUST be placed in a position which vents/removes all pressure from the tank beforehand.
Another ball-valve is fitted to the lowest point of the tank to test/drain for any water. (And a clear tube can be connected between the open drain and the vent valves to allow fuel to enter that tube so tank quantity/contents can be seen, if necessary.) I have no meter on it because I don't feel it necessary for my operation...I keep a log on my fuel delivery into the equipment related to the hour-meters on that equip't. I have the diesel for my Kubota M4700DT tractor, the RTV-X900, and a Ferguson 5-8B Compactor/Roller (has a John Deere 4329 engine) for maintaining my turf airplane runways among other things. (Hogs sometimes dig up the runways and the roller mashes it back smooth very easily, and compacts the ground which has caused the hogs to lose interest in that area.)
The state laws allow a farmer/rancher to transport fuel in tanks that are not permanently attached to a trailer, so I have farm tags on my trailer which also exempts from Federal HazMat laws in my state, and I only have 7 miles via back-roads to my distributor. I've spent about $125 on building this system and the first 140 gals of fuel purchased was at a price that more than made up that amount. The only concern was whether or not I'd use that much fuel in a year, so I've treated the fuel with Diesel-Sta-Bil and Biobor JF biocide (which is what we used in the jets I flew corporately) to prevent issues with cetane or biologicals. (It turns out I use about twice that amount and refill it about every 6 months.)
The only issue I've had was a need to re-construct the dip-tube after I discovered pressurized air foaming the fuel delivery. The first dip-tube was threaded in to a reducer screwed into the underside/top of that "T" which also brings pressurized-air into the tank. That NPT style of thread prevented a perfect seal on the underneath side of the reducer, so my second dip-tube was threaded, welded, and then sealed with JB-Weld before installation into the "T", and that has solved the foaming problem.
I plan next to fabricate a 10-ga. metal cover which will hinge/flip-over to replace the correct-color upside-down Home Depot bucket that presently protects the filter/valve system from the elements. I don't have a theft problem where I'm located (in the middle of 1500 acres and 2 miles from the nearest county road...anyone who gets to my place either belongs here or is lost and had to get thru a security gate a half-mile away also)...but a lock could easily be placed on the cover (in case the potential thief happened to bring his air compressor to drive the system.)
Hope this is useful for others. The FILTER on this setup was purchased at Tractor Supply and removes both debris AND water.
Disregard the “wet look” in these photos,...it had just rained. (I posted this previously but apparently forgot to hit “save”...so here it is again.)
