Engine system failure /Malfunction warning light
therbick
Anyone know where I can get the DTC error code list for a Mahindra 1640. I have an engine system failure /Malfunction warning light. the tractor only has 235 hours on it I have already change the fuel filters and verified levels and such. Any help would be greatly appreciated.
Check the other thread you started for info.
So I got a code P0204 (Injector circuit/Open cylinder #4). A couple of questions what is the likely cause for this code and which cylinder is number 4 on a 1640 Mahindra closest to the front or cab? Thanks.
Tom
A P0204 is a pretty universal code. An internet search will give you causes and resolutions.
Look on your cylinder head to see if there's markings for 1-4. It may be right in the casting.
Well that's not good. You reset it with an OBD tool? Is it giving you any other codes right now (like why it won't start)?
Does it crank? Click? Dash lights on?
Yes, I reset the code with a new OBD tool. Yes, the dash lights work, no other codes. It will not crank. Battier voltage is good. I afraid it deleted something in the brain. I don't know.
Do you have a starter jumper box? If so, connect it right to the starter and get a good ground and try to start it.
Yes, I do. I will give that I try. I may not work if the EDC isn't controlling the injection. I agree, should turn over.
