I am installing front and rear nilight light bars onto my dads Kubota RTV-X1100c that has cab and factory installed wiring already set up. We purchased the Kubota switches with the five wire connection that easily plugs into the connectors in the front inside roof. We installed the front light bar, and switch and it turns on and works well. When we did the identical set up for the rear light, it doesn’t work. The rear light switch has power since it has a little light on it, and we tested the light bar separately and it works, but we can not figure out why it won’t work when connected to the rear wiring. I noticed there is only one “worklight” fuse in the fuse box.
Does anyone have a wiring diagram for the factory installed accessory wiring harness? Anyone have any ideas to help?
